All About Brakes
This page is under construction. We are working to make a great resource for all information brake related. They just slow you down. Leave comments below for what you would like to see.
One response to “All About Brakes”
  1. grulich69 Avatar
    grulich69
    I want to know what kind of brake fluid I should use
Leave a Reply
Your email address will not be published. Required fields are marked *
Learn All About Brakes
Take action now and learn everything about brake maintenance.
Frequently Asked Questions
Brake Pad Options
We offer a variety of brake pads to suit your vehicle’s needs, including ceramic, semi-metallic, and organic options. Please consult with our technicians to determine the best fit for your specific driving needs and preferences.
Brake Fluid Recommendations
We recommend using high-quality brake fluid, such as DOT 3 or DOT 4, to ensure optimal brake performance and longevity.
Brake Caliper Maintenance
Regular maintenance of your brake calipers is crucial to ensure proper braking. Our technicians can inspect and service your calipers as needed, including lubricating slide pins and replacing worn or damaged components.
What kind of brake fluid do you use?
View Results
Loading ... Loading ...
